Hello!
I’m trying to make a compact system to run audio to powered speakers and to run led tape.
Here’s the premise of the show!
Audience members are invited to stay the night in 1 of 30 hotels rooms. Within the room audio will be played back through an active speaker. The audio track will be a 9 hour long fully composed sound track designed to envoke lucid dreaming. The audio needs to be automated to start at a specific time. Along with the audio there will be LED tape in the room which will turn off when the audio starts to play and will then switch of upon the audios conclusion.
I have a general idea on how to do this, but I need some help!
Currently I’m thinking of using an arduino uno as the base controller. Attached to this a micro SD card module (because the soundtrack is so long) and an audio jack breakout board with a 3.5mm audio jack. Aux will run to the speaker from the jack for playback. LED tape I’ve done before so i’m not too worried about that.
I’ve attached a schematic, if anyone can tell me if this would work it would be great!
McLane
