Core Electronics Forum
Auto Ranging Digital Multimeter with USB Datalogging (AQ1071A)
This is a placeholder topic for “Auto Ranging Digital Multimeter with USB Datalogging” comments.
This top quality auto ranging meter is capable of logging measurements to an internal memory for later review. The push button control layout employed allows easy one handed operation.The LCD simultaneously displays date, time, bar graph and the measured reading. A backlight is provided allowing you to work in low light. It samples at a rate of 3 measurements per second for up to 11 minutes of recorded data. It is capable of measuring resistance, frequency, duty cycle, capacitance, continuity, AC/DC voltage and current up to 10A. In addition, data hold and relative measurement modes are also provided. Includes high quality rubber insulated test leads and is housed in a shock-proof rubber coated case. Includes 2 x AAA batteries, 1 pair Test leads, 1 pair thermocouple banana probes, USB lead, mini CD ROM Features Auto ranging USB connection for datalogging to a PC Min/max recording Push button controls Duty cycle % range Bar graph display Data hold and relative modes Continuity buzzer and diode check Battery included Frequency measurement Time & date display Auto power off Cat III 600V.
Hi there, this is still on the webpage as part of the clearance sale. Is this still available ?
Hi Patricia,
The clearance sale is no longer active. This part is still available at regular price.
