Biometric sensor (Heart rate, Pulse oximeter) (CE09443)
This is a placeholder topic for “Biometric sensor (Heart rate, Pulse oximeter)” comments.
You’ve probably used sensors to check in on the environment, but have you ever read your pulse? Literally, sense each heartbeat with this heart rate and pulse oximeter sensor.
This Core Electronics device has 8 pins
GND RD IRD INT
VIN SDA SCL GND
Do they all have to be connected? If so, where should RD IRD INT be connected on a RPi?
Hi @John265780
Looking at the data sheet, INT would be an interrupt pin, this may be required depending on your application. RD and IRD will not be required at all.
Hi I need the schematics and board files for this.
Hey @Mrunmoy61001 , Welcome to the forums!
Unfortunately, we don’t have any schematics or board files for this product however, we do have the datasheet for the MAX30102 sensor used on the board, if that would be useful for you.
Hope this helps!
