Good day,
How to get the force output (N or kg) from the RP-S40-ST hooked up to Arduino?
Methods I have tried but didn’t get the correct force reading on Arduino console:
Use the equation from the pressure sensor data sheet:
fsrForce = 271*pow(fsrResistance,-0.69)
[Data Sheet of RP-S40-ST Rev A (eleparts.co.kr)]
Ref:
(http://m.eleparts.co.kr/data/_gextends/good-pdf/201904/good-pdf-7495470-1.pdf)
- How to get the data from the graph on RP-S40-ST product page shown below?
Any help to calibrate or get close to accurate force reading from the RP-S40-ST pressure sensor would be appreciated, attached the code of my Arduino below. Hope it helps explain better
int fsrPin = 0; // the FSR and 10K pulldown are connected to a0
int fsrReading; // the analog reading from the FSR resistor divider
int fsrVoltage; // the analog reading converted to voltage
unsigned long fsrResistance; // The voltage converted to resistance, can be very big so make "long"
unsigned long fsrConductance;
float fsrForce; // Finally, the resistance converted to force
void setup(void) {
Serial.begin(9600); // We'll send debugging information via the Serial monitor
void loop(void) {
fsrReading = analogRead(fsrPin);
Serial.print("Analog reading = ");
Serial.println(fsrReading);
// analog voltage reading ranges from about 0 to 1023 which maps to 0V to 5V (= 5000mV)
fsrVoltage = map(fsrReading, 0, 1023, 0, 5000);
Serial.print("Voltage reading in mV = ");
Serial.println(fsrVoltage);
if (fsrVoltage == 0) {
Serial.println("No pressure");
} else {
// The voltage = Vcc * R / (R + FSR) where R = 10K and Vcc = 5V
// so FSR = ((Vcc - V) * R) / V yay math!
fsrResistance = 5000 - fsrVoltage; // fsrVoltage is in millivolts so 5V = 5000mV
fsrResistance *= 10000; // 10K resistor
fsrResistance /= fsrVoltage;
Serial.print("FSR resistance in ohms = ");
Serial.println(fsrResistance);
fsrForce = 271*pow(fsrResistance,-0.69);
Serial.print("Force in KG: ");
Serial.println(fsrForce);
Serial.println("--------------------");
delay(1000);
