Core Electronics Forum
Case and Display Case compatibility
Is https://core-electronics.com.au/pimoroni-pibow-3-coupe-ninja-raspberry-pi-3-2-b.html compatible with the new rpi 3b+?
Additionally if you were to mount a rpi 3b+ to https://core-electronics.com.au/pimoroni-raspberry-pi-7-touchscreen-display-case-noir.html can you also protect the rpi using the above rpi case too when mounted?
Can all three parts be used together…
Thanks,
Clint.
Hi Clint,
The Pimoroni Pibow 3 Coupé Ninja (Raspberry Pi 3, 2, & B+) is compatible with the Raspberry Pi 3 B+.
Also you should be able to mount a Raspberry Pi 3B+ to the Pimoroni Raspberry Pi 7 Touchscreen Display Case.
A couple things to be aware of, the screen is not included with the Pimoroni Touchscreen Display Case, and the Raspberry Pi actually mounts to the back of the screen, and you will need longer bolts to pass through the whole case if you want to secure it the same way.
Good luck on your project!
