For this product, Large Ultrasonic (Sonar) Sensor with Horn and UART Output | Adafruit ADA4664 | Core Electronics Australia would connect a male to male jumper wire to it work as usual? I am doing a project where the controller board end only has female connectors but I want to use this ultrasonic sensor for development.
Hi Boyang,
Welcome to the forum!!
I’d say the 2mm pitch on the end of the connector is a bit too tight to fit jumper wires into.
With a wire stripper and some crimp connectors (+ housings + If you don’t have a crimping tool)
You can add your own male connections to the wire, PS: there is a good guide here: How To Make and Crimp Custom Connectors - Tutorial Australia
