I have a question on a connector which Im unsure how to find and order from your catalogue
I’ve attached a picture of the ends I need to connect into - it connects a motor to an ESC.
There are 3 male connections
I need to build the x3 female connections to fit.
The width looks like its 3.5mm wide (4mm wide at the flange) and the length is about 6mm
Would you be able to recommend product to build a connector to these 3 .
Im attaching a photo of the connector pins.
Hi Kelvin,
Welcome to the forum!!
It looks like these ones will be HXT connectors. Unfortunately I couldnt track anything down on the Core website.
They can handle up to around 50A from what I came across so be doubly sure that when you solder them up there is a very good connection.
Hi Kelvin,
I’ve heard those connectors colloquially called bullet connectors and I believe they are the same kind that is used in the XT30/60/90 series of connectors that we do stock. Bullet Connector Australia
I think Liam is on the money though if you needed loose connectors to connect to an ESC his link is probably the best bet.
