Creating PiicoDev Fritzing parts
I have tried my hand at creating a Fritzing part for the PiicoDev colour sensor, VEML6040. I am very much a novice at all of this (graphic design and electrical circuitry) and am doing it specifically to create graphical representations of circuit designs using PiicoDev products for students. Are there any legal or other ramifications associated with making this one (and any others I create) public? I have attached the svg file I used to create the Fritzing breadboard image (I can’t attach the Fritzing zip file). It does have the PiicoDev name on it. I have not attached the PCB view file, but it would not be suitable for creating a PCB. I am happy to make anything I create public and receive community feedback, but I wouldn’t want to make Core Electronics look amateurish through my own naivety.
Core_PiicoDev_VEML6040_breadboard
To me it does not look bad. As far as I know, there should not be any legal issues with it. I hope core electronics will answer soon.
Hey @David55659! We’re honestly stoked you took the initiative - of course you’re welcome to create artwork to document PiicoDev in your projects! Sharing is the last step in making, and Fritzing diagrams help document your work and add to the wonderful rising-tide that is Open Source.
Insider intel: we’ve toyed with the idea of getting in touch with Fritzing and having them put together some really mint PiicoDev models to be distributed with the standard build of Fritzing. Their hourly rate is pretty reasonable and they do a great job. Later is better for us, because we’ll have more modules in the future to hand over to them.
Consider open-sourcing your work so others may benefit too!
Love your work - happy making!
Thanks, @Michael. I have only made the one part at the moment, but it shouldn’t be too difficult to make more based on that one. I have put it up on GitHub (I’m new to that, as well). Any feedback would be much appreciated. The GitHub link is https://github.com/davidebert/PiicoDev-FritzingParts
Looks amazing David!!
Very vibrant :slight_smile: I cant wait to see projects come through with these being used.
Using the KiCAD board viewer should speed things up if you’re looking to pump out modules, if you’re keen let us know and we can send through some resources!
Thanks, @Liam. I am very much the rookie at this. I’ve never used KiCAD and am only just learning Inkscape. Can KiCAD generate .svg files suitable for making the breadboard image? What other resources do you have? I only have a few days before I am back in the classroom and may not get back to this for another 10 weeks. :smiling_face_with_tear:
Hi David,
I just tested the KiCAD export feature and it looks like you can! Here’s some results for an up-coming project:
This is a couple of the copper layers, it isn’t quite the full rendering but should be able to get you started - the 'front silk screen and courtyards will be the ones you want to grab :slight_smile:
And if you just wanna have a look to trace or grab a nice screenshot use the 3D viewer
And the result without any components rendered (from memory most of Core’s do)
Here’s some links that you might find handy:
Once the project is loaded open the pcb file then you can
File > Export SVG
Hello @David55659 ,
I am a high school teacher documenting project layouts for use by my students using Fritzing so very much appreciate the time you have taken to make and share this.
Thanks!
Hi @matt_chadwick ,
I’m a high school teacher, too. Still looking for the time to follow through with my original ambition!
It is hard to believe it is three years since I said I would be getting back to this in 10 weeks. I have created a few more Fritzing parts for PiicoDev modules. I will continue to work through more but thought I would put these up for people to look at and make sure I am on the right track. At the moment I have just dropped the .fzpz files into a Google Drive folder. You should be able to download and import those files into your My Parts bin within Fritzing. Please read my “disclaimer” in my original post from July of 2022. That bit hasn’t changed much. The only thing that has changed is I am now retired and have a bit more time for fiddling.
Feedback most welcome!
I haven’t seen any other PiicoDev Fritzing parts, so I am assuming the possibility that @Michael mentioned of making professionally designed modules part of the standard Fritzing part library never materialised. If it has, I have no desire to double up effort when my parts will never be fully functional Fritzing designs.
Hey @David55659,
Great to see you back at it, and with more PiicoDev Fritzing parts! Thanks for sharing the .fzpz files and for keeping the project moving forward. Having these parts available, even if they’re not “fully functional” in Fritzing’s deeper simulation sense, is still a huge help for anyone doing PiicoDev-based layouts.
I don’t believe the “professionally designed modules in the standard Fritzing library” idea ever ended up happening, so your work here is definitely filling a gap.
After a brief step out of retirement and back into the science classroom, I have finished creating 24 PiicoDev module Fritzing parts, as well as a Fritzing version of the PiicoDev expansion board for the Raspberry Pi Pico. I have taken my initial versions out of the Google Drive and posted all to GitHub. I am currently writing a submission for the Core Electronics Projects page with a description of how to use the parts effectively in Fritzing and a couple of simple example projects. I do hope someone will find this useful. I have had a lot of fun creating the parts and learned a lot along the way! Happy to receive any feedback/suggestions for improvements.
Hi David,
How epic! They turned out great :smiley:
Its a shame Fritzing doesnt have a link of ‘ribbon cable’ or bus where you can combine multiple connections. We’re super keen to see that project come through (and to learn a bit more about your trials and tribulations).
The PiicoDev platform is such a great addition.
