The GPS supplied with WS-21707 works fine.
The problem for me the cable is too long for my application so I ordered the GPS-00177.
I cant seem to get a GPS signal from that GPS.
Any Ideas please ? Specs look the same especially frequency etc etc.
Matt
Just for a quick check have a look at the sma connectors feom both antennas, do the look 100% the same, eg does one have a pin and the other one not?
Yes 100% GPS is a male and the SIM is a female so coinnection is good.
Matt
The reason i ask is there are 4 sma connector types not just two.
The 2nd antenna states it has a lna which implies it needs power. As such if the gps unit is not providing the needed power it may not work.
Note, I’m just having an educated guess from a very quick read of the specs on my phone, so may be missing something.
Does the original antenna have a part number printed on it?
Hey, no it just states the frequency which is 1575.42MHz and that’s the same as the one just supplied when you check the specs.
Matt
Cheers. I think wait for one of the core guys to have a look.
To me it looks like the new antenna is active which needs power, but the original is passive and does not need power.
As such unless there is a way to turn on power to the antenna, you may need to find a different one.
Anyway lets see what the experts say.
Hi Matthew,
From a bit of digging it looks like the antenna included with the WS-21707 ( SIM7600G-H M.2 4G HAT for Raspberry Pi includes a passive antenna, though from the schematic there is a biasing circuit for (something? Good catch Michael!) similar to that of the Sparkfun unit.
Might be worth an email?
EDIT:
I think the biasing circuitry is not populated on your version of the HAT:
From (your one) SIM7600G-H M.2 4G HAT for Raspberry Pi, LTE CAT4 High Speed, 4G/3G/2G, GNSS, Global Band | Buy in Australia | WS-21707 | Core Electronics :
From https://core-electronics.com.au/waveshare-4g-hat-for-raspberry-pi-lte-cat-4-4g-3g-2g-gnss.html:
But annoyingly both use the same schematic, a fun bit of sleuthing!
In short, Michael is right (if that area in red isn’t populated on your board)
In short a passive antenna will work: https://core-electronics.com.au/catalogsearch/result/?q=ADA2461%20ADA2460%20
