DC Mini Immersible Water Pump (6V~18V) (FIT0563)
Hi Clay
Just had a look at the specs. some below
  • Power supply: 6~18V DC,65mA-500mA
  • Interface: DC 5.5
  • Pumping head: 60-420cm
  • Capacity: 280~500L/H
    It looks like the pumping head at 6v is 60cm. A bit short of your required 1 meter. I am a bit surprised at that but it is an impeller type pump which will not have the capability of a piston type.
So it looks like your 6V may not be quite enough. Trial in your particular situation will be the only way out.
Hi Bob,
Thank you so much for the information, I guess I will try the 12 v battery and see how it goes :slight_smile:
Clay
Hi Bob,
My apology to ask a question again but for the capacity 280 to 500 L/H, L/H just mean liter per hour, right?
Hi Clay.
Yes.
Hi Bob,
Thank you so much for your reply :slight_smile:
Have a good Easter break.
Kind regards,
Clay
Will this pump cavitate if ran dry?
Hi Pat
It certainly won’t pump water but if it is submerged it should self prime.
What’s the diameter of the output nozzle?
Hi Zero
It is all on the description page
  • Dimensions: 45x43x30mm(1.77x1.69x1.18")
  • Output pipe
    • Outer diameter including barbs: 9-10mm
    • Inner diameter: 6.5mm
  • Input pipe
    • Outer diameter: 12mm
It wasn’t until I sent an email asking them, but thanks
Why am I not surprised.
