Hey guys, I’m a bit of a novice, but I’ve built an app for our business and part of the app is set up as a POS that mimics a square terminal. I was wondering could I run our web based app in portrait mode on this display easily to use as a POS? Thanks!
Hey there, @Hamish334243, and welcome to the forum. Glad to have you here.
I’m presuming when you mention a ‘Web-Based App’ you mean a browser based application? If so, this would not work. Its not a display in the same way that a monitor is, it actually uses the built-in ESP32-S3 microcontroller which does not have the ability to display web content. You would be better off using a Raspberry and a DPI display, which can run web applications through a browser.
If, however, you just mean that the app uses the web, you could eventually use this screen, but you would need to code a dedicated graphical interface for it. You would typically use a library such as LVGL, and connect that interface to your app’s backend. Portrait orientation and touch configuration would also need to be programmed in.
Hi Jane, perfect thank you, yes browser based. I have set up a pi to run a monitor before, so I’ll look into that a bit more. Cheers!
