Has anyone had success in pairing a DSI touch panel with the ESP32-P4, namely the DFROBOT DFR1172. I am using VSC, and ESP-IDF, but with every possible driver configuration i was unable to even get the backlight on, let alone an image. The ESP32-P4 is very capable for a micro, but i havent had as much success as i had hoped.
Troubleshooting
- i know the WS-24160 works as it worked on a RPI out of the box.
- I know i have the DSI cable correct on the ESP32, as the touch I2C works. but the display and backlight control do not.
Waveshares advice was short… and basically said no it wont work it is for a RPI, just purchase a 4.3-DSI-TOUCH-A instead for the ESP32.
The Waveshare-esp32-components repo did not list support for this display, maybe that should have been my first tell. But you know how it is sometimes you purchase hardware, and then look at integrating…
Looking for 1 of 2 options. Ideally someone has a working version of this configuration as posted. Or 2, is there a display at Core Electronics that will work with the ESP32-P4 (4- 5 inch touch)
