Hi guys. I’m trying to connect a fast vibration sensor to an electronic doorbell powered by a 9v battery. I want the vibration sensor to act as the switch instead of a push button bell. The sensor will be attached to a ships bell, hence the vibration sensor. I have been advised I may need a relay. I prefer to not use an arduno board in this stance.
The doorbell will dictate what you need. For instance, this item Fast Vibration Sensor Switch (Easy to trigger) Australia (core-electronics.com.au)
will switch 20ma, which is enough for a typical logic circuit. If the doorbell switch is driving some sort of IC to generate the tone (for instance, if it’s a wireless doorbell and the switch is connected to some logic in a controller board) then 20ma will be adequate. If the doorbell switches power to a buzzer then it is likely it is switching more than 20ma and you will need a sensor that switches a higher current, or a driver of some type such as a relay.
You also need to consider what type of switching the doorbell can handle. A simple vibration sensor will likely trigger multiple times in rapid succession. A more complex arrangement will trigger once and then do nothing for a certain short period before it can trigger again. If the doorbell can’t cope with multiple rapid switches then you need to allow for that.
So the place to start is with the connection to the doorbell.
Hi Jeff. Thanks for your informative response. I’ve attempted to attach a picture. The door bell is a wired electromagnetic doorbell.
I believe purchasing an appropriate relay maybe the best course of action at this stage.
I take note of the potential for the vibration switch to trigger multiple times and will need to compensate for this issue.
As you can probably tell I’m a complete novice but keen on expanding my (basic) knowledge for this project. I am also open to other suggestions in relation to attaching a buzzer/bell to my ship bell or if a more appropriate trigger is available.
I assume u mean so I can utilise the push button from the bell. The issue still remains creating / installing a switch that closes the circuits when the bell is rung. Ideally I do not want to use a push button switch at all.
As @Jeff105671 has covered the fast vibration sensors are only rated to 20mA and your doorbell seems to consist of a power supply, a solenoid, and a switch. The vibration sensor won’t be able to directly substitute for the switch as it doesn’t have the current rating, you will need either a sensor capable of more current or a relay for the vibration sensors to interface through.
You may not require a microcontroller but it will depend on how long your vibration sensor stays “on” after knock. The added complexity of a relay isn’t too bad, you could use the doorbells battery, and a current limiting resistor to protect the vibration sensor, then just wire the output side of the relay in place of the doorbell switch.
Might be worth connecting your vibration sensor (with relay as required) up to a small microcontroller board. If it were me, I’d be connecting to an ESP8266 with Tasmota installed on it, but if be looking to maximise possible connectivity and hooking into my Openhab system. Anything you do to make the connection between the bells go via some standard protocol will pay off if you wish to add more features in the future, such as triggering a camera to let you see who’s there.
