From ultralytics import YOLOE - Process ended with exit code -9
**from ultralytics import YOLOE
Initialize a YOLOE model
model = YOLOE(“yoloe-26l-seg-pf.pt”)
Run prediction. No prompts required.
results = model.predict(“path/to/image.jpg”)
Show results
results[0].show()**
1 accessory, 1 array, 1 bank vault…
What does it mean?
Hey there, @Bill293536,
Process 9 indicates that Python was terminated by the Operating System, usually because the device has run out of memory.
May I ask what you were doing when you got this process code?
Jane,
Hi.
:slight_smile:
Run:
image 1/1 /home/pi/Desktop/image.jpg: 384x640 1 accessory, 1 array, 1 atrium, 1 back vault, 2 baskets……
Speed: 266ms preprocess……
Bill
Thanks for that, Bob,
Could you please confirm if you’re using the same guide from last time or are you using a different guide?
I have been comparing your code to that set out in Custom Object Detection Models Without Training | YOLOE & Raspberry Pi and I’m noting that code is written as:
# Capture a frame from the camera
frame = picam2.capture_array()
# Run YOLOE model on the captured frame
results = model.predict(frame)
Whereas you seem to be passing the direct image file to the predict method instead of what is returned by picam2.capture_array() object.
Can I confirm what guide you are using so I can better see what might be going wrong?
Whagt
Jane,
:slight_smile:
First: A port of Debian Bookworm
Second: Core - How to set up YOLO computer vision on a Rasberry PI - conda & Ultraclytics
Third:
Show results
results[0].show()
Fourth:
RUN
Bill
Hey @Bill293536,
Does running the original code from the guide work?
import cv2
from picamera2 import Picamera2
# Set up the camera with Picam
picam2 = Picamera2()
picam2.preview_configuration.main.size = (800, 800)
picam2.preview_configuration.main.format = "RGB888"
picam2.preview_configuration.align()
picam2.configure("preview")
picam2.start()
# Load YOLOE prompt-free model
model = YOLO("yoloe-11s-seg.pt")
while True:
    # Output the visual detection data
    annotated_frame = results[0].plot(boxes=True, masks=False)
    # Get inference time
    inference_time = results[0].speed['inference']
    fps = 1000 / inference_time  # Convert to milliseconds
    text = f'FPS: {fps:.1f}'
    # Define font and position
    font = cv2.FONT_HERSHEY_SIMPLEX
    text_size = cv2.getTextSize(text, font, 1, 2)[0]
    text_x = annotated_frame.shape[1] - text_size[0] - 10  # 10 pixels from the right
    text_y = text_size[1] + 10  # 10 pixels from the top
    # Draw the text on the annotated frame
    cv2.putText(annotated_frame, text, (text_x, text_y), font, 1, (255, 255, 255), 2, cv2.LINE_AA)
    # Display the resulting frame
    cv2.imshow("Camera", annotated_frame)
    # Exit the program if q is pressed
    if cv2.waitKey(1) == ord("q"):
        break
# Close all windows
cv2.destroyAllWindows()
It looks like you are trying to run a very large version of the newest YOLO26 model, I havent tested it, and the only thing I’m finding about that exit code is your Pi running out of RAM.
Jaryd, Jane,
:slight_smile:
Does running the original code from the guide work? Yes, it seems to work fine.
It is the Ultralytics code which fail to work. And I see why known.
:slight_smile:
Thank you very much.
Bill
