Hi first time post here…
I’ve just finished a fun “Fruitbox” (a JukeBox….) Pi project and have finish the 3D printed case and all the hardware etc.
The problem is that I can’t seem to get the command line below to autorun on start -up.
Sudo ./fruitbox –cfg skins/TouchOne/fruitbox.cfg
Just using raspbian-buster…… pi 3b+ with a 7” touch screen. All the fruitbox setup runs 100% as per chundermike’s guide (see chundermike/rpi-fruitbox: Raspberry Pi fruitbox (github.com)).
What is the recommended way to do this??
I think I’m missing something obvious.
Any help appreciated…
Hey!
Out of interest, why the sudo? Wouldn’t it be better left off and run as the local user?
But I think the file you’re looking for is /etc/xdg/lxsession/LXDE-pi/autostart, you should just be able to put your launch commands in there (not tested myself).
What other approaches have you taken? Keep in mind you can’t launch a GUI application in an environment without a display set (such as crontab).
(also - epic print! love your jukebox!)
Just got it working:
Used nano to edit ( sudo crontab -e)
I add the line: @reboot (cd /home/pi/rpi-fruitbox-master; ./fruitbox –cfg skins/TouchOne/fruitbox.cfg ) /tmp/fruitbox.log 2>&1
Seems fine… but maybe crontab isn’t the best way to go.
Hi Bruce,
Welcome to the forum
That is a seriously tidy looking project! Must have taken a while to print all the parts too.
Yes a few large parts… I used the work of JPRanger18 on Thingiverse as a starting point and re worked it. See Raspberry Pi Jukebox by JPRanger18 - Thingiverse Then many coats of high build acrylic spray putty followed by top coat and clear gloss…
Bruce
