Gravity: Heart Rate Monitor Sensor (SEN0213)
This is a placeholder topic for “Gravity: Heart Rate Monitor Sensor” comments.
The DFRobot Heart Rate Monitor Sensor is used to measure the electrical activity of the heart. This electrical activity can be charted as an ECG and output as an analog reading. An ECG signal can be extremely noisy so we have included an AD8232 chip on the PCB which will provide a clear signal from the PR and QT Intervals. Using the Arduino IDE “Serial Plotter” feature you are also able to view plotted ECG output on your PC!
Hi, I want to use your DFRobot Heart Rate sensor SEN0213. It looks like it doesn’t come with electrodes, do you sell compatible electrodes for measuring ECG electrical activity on the chest?
This whole package contains the following parts- * Heart Rate Monitor Sensor x1
Excellent, thanks!
Shervin.
http://shervinemami.com/
Hey @Shervin13688 , welcome to the forums!
@ahsrab292840 is spot on that they already come with a sensor cable in the box. If you need, we do also sell spares at the following link:
Hope this helps!
