Make your own custom HDMI cable or HDMI interface with ease, using this HDMI Terminal Block Breakout. You get a nice solid PCB with an HDMI plug and two strips of … read more
Yes, but the colors of the wires may not follow a “standard” configuration. You would need to know where each wire needs to be terminated. A female breakout on the other end of the wire would allow you to check them with a meter.
Most manufacturers are willy-nilly with the colours that are used in cables so the best way to confirm is by getting a matching socket and ‘beeping’ out connections with a multimeter
