This is a placeholder topic for “Heat set insert kit (M2-M6, 300pcs total)” comments.
Add robust threads to your thermoplastic creations!
Read moreThis is a placeholder topic for “Heat set insert kit (M2-M6, 300pcs total)” comments.
Read more90% of the time I’m using m3.
Can you buys these in smaller quants, like 10pc, all M3?
Hey @Pixmusix
We stock Brass Heat-Set Inserts for Plastic - M3 x 4mm - 50 pack | Buy in Australia | ADA4255 | Adafruit | Core Electronics and Brass Heat-Set Inserts for Plastic - M3 x 3mm - 50 pack | Buy in Australia | ADA4256 | Adafruit | Core Electronics that are dedicated M3 packs, they are both 50pc packs so you will have plenty ready to go if you need.
Hi Jonny,
I’ve got a bunch of other similar hardware in a suggestion list to send through to Core, I’ll let them know youre after some M3.
Do you think there is a best size/QTY? Say 4mm of thread and 20 instead of 10? Like resistors, it’s better to have too many than not enough
