I recently purchased 2 genuine Arduino Uno R3 boards from Core Electronics. Since arriving I have been unable to get either board to accept an upload.
Initially I was unable to get my computer to even recognise the first board, it wasn’t until I plugged the second one in and it showed up successfully that I then worked out that it appears that the USB to Serial firmware was corrupted on the first board. After going through the steps required to flash the new usb-to-serial firmware https://support.arduino.cc/hc/en-us/articles/4408887452434-Flash-USB-to-serial-firmware-in-DFU-mode it was able to be detected successfully.
However my original problem remains and both boards have the same issue so I cant work out what else I can try to fix it.
I am not trying to upload my own code at this point so it shouldn’t be an issue there. I am simply trying to upload ‘Blink’ from the supplied examples. I downloaded the windows installer for the IDE from the official website and it installed Arduino 1.8.19.
Upon attempting to upload I get the following error
Arduino: 1.8.19 (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\User\AppData\Local\Temp\arduino_build_399989/Blink.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\User\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc3
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc3
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I have ensured that the correct port is selected and board type is UNO
I have tried with 2 different USB cables and 3 computers and I get the same error each time. Which makes me lean towards a hardware issue, however I was able to successfully perform a loopback test.
I have tried uninstalling and reinstalling the IDE, I have pushed the reset button in many various ways as suggested by several different google searches. Long press, 2 quick presses, hold while clicking upload etc. Nothing has worked.
The only thing I have not been able to try and which is suggested as the last resort by all the help topics is to reprogram the bootloader. I do not have the correct equipment or a spare working uno to attempt this.
I find it difficult to believe that two brand new boards would both have a corrupted bootloader but I am out of ideas and willing to attempt any reasonable suggestion.
