Posted a while ago while getting setup, and have run into a really confusing issues.
I setup like this
I installed WLED through their installer site.
Once it was all wired up I hooked it up to the power and it all lit up in plain white. (I did a small dance of joy at managing that)
I then tried to login to the WLED and it wouldn’t load, checked my network and the WLED wasn’t showing up.
I plugged the micro USB into my laptop and was able to access the WLED controls, but I had to disconnect power to the LEDs for it to connect, because if I had the power and the micro USB connected no lights lit up at all
I then setup the pattern/playlist I wanted (fire pattern), set it to autoplay on boot, and saved.
Unplugged the micro USB and reconnected the power, and then half the lights were flashing random colours. (The first half of the lights like power wasn’t getting all the way through, but it had originally lit up with full brightness all the way through)
I disconnected the power and reconnected the micro USB to adjust the programming again.
Reconnected the power and it was flashing a different random pattern on only the first half.
Frustrated, I disconnected the power, and went to bed hoping to go fresh today.
Well… Hooked the power up again today and nothing… Not a single weak flashing light.
This is what it looks like right now.
The esp32 is a duinotech wearable. (Bought after I had issues with the esp8266 I had originally)
There are 3m of WS2811 LEDs
And a 12v to 5v converter from the battery to the esp32
What the hell has happened? What can I do?
Why won’t the esp32 connect to my wifi without the micro USB?
Why did half the lights drop out after they all lit up the first time?
How do I fix this… I am at a huge time crunch at this point.
Please please help
