Hi there,
Thanks for taking the time to help me out!
On the Arduino program, I’m trying to control the speed of my micro servo so that it rotates 180 degrees based on how much water is flowing through my water sensor.
I currently have “delay” to control the speed but I don’t think this will work in sync with water flowing through my sensor. Do you have any suggestions of particular code I can use to make this work?
Here is what I have at the moment:
#include <Servo.h>
Servo servo_test; //initialize a servo object for the connected servo
int angle = 0;
volatile double waterFlow;
void setup() {
Serial.begin(9600); //baudrate
waterFlow = 0;
attachInterrupt(0, pulse, RISING); //DIGITAL Pin 2: Interrupt 0
servo_test.attach(9); // attach the signal pin of servo to pin9 of arduino
void loop() {
Serial.print("waterFlow:");
Serial.print(waterFlow);
Serial.println("L");
delay(500);
const int angleIncrement = 1;
const int incrementDelay = waterFlow;
for (int angle = 0; angle < 180; angle += angleIncrement) { // single "degree" increments
servo_test.write (angle);
delay (incrementDelay);
for (angle = 180; angle >= 1; angle -= 10) // command to move from 180 degrees to 0 degrees
servo_test.write(angle); //command to rotate the servo to the specified angle
delay(1000*waterFlow);
void pulse() //measure the quantity of square wave
waterFlow += 1.0 / 450.0;
Thanks for your help!
Declan
