Hey all, just put the finishing Bow on the guide “How To Replace Your FEP Film - Resin Printer Maintenance Tip”.
I’ve done this process a couple of times and have refined it
so come see exactly how I do it and save yourself making my mistakes. Replacing a FEP is a normal part of the life of a Resin 3D Maker, so come learn the Elite Method.
After owning a resin printer for some time at a certain point you will need to replace the original FEP Release Film that comes installed from the factory on a DLP or SLA machine with a new one. These are wearable components and if left on too long will result in less sharp and less reliable prints.
Note! A new FEP often has transparent protective coverings on either side of it that can be very hard to see. Make sure to peel those two protective surfaces off before installing!
