Hi, I’ve purchased some hydro film, usually it comes with a paper backing, but this stuff is clear, so I’m unsure which side to print on, can anyone help me here?
Hey Ben, Welcome to the forum!
You can lick your thumb and finger and pinch the sheet, one side will stick to your finger, and that’s the one that will absorb the ink and release onto the water.
Hope this helps!
Ok thanks. So the same side I print on, faces up when being put into the water?
Hi Ben,
That’s correct! Let us know how you go
Yep, that way the plastic dissolves and leaves the ink behind floating on the surface.
