Generally, the the black ring on on the connector means that it’s an RF switch, rather than an RF connector. What this means is that when you plug in an antenna, something in the connector is deflected and disconnects the antenna on the board (they can’t both be used at the same time, and using neither will damage the RF circuitry, so a switch handles all this).
I had a look at the ranges of Amphenol and Hirose and couldn’t find an exact match, but maybe other manufacturers like MuRata might have something.
And don’t forget, you may be able to get this info from Lexmark, or build your own print server with a raspberry Pi over ethernet if you require a better connection, or place a WiFi AP or repeater right next to the printer.
