Hi
Does anyone have code or libraries to get this to work on the RPI Pico using micropython?
Hi
Hi Clint,
I took a look and it seems no-one has ported this one to MicroPython ![]()
Though the product wiki gives some simple example code that could be ported over to a Pico easily:
#include "Wire.h"
#define address 0x40
char dtaUart[15];
char dtaLen = 0;
uint8_t Data[100] = {0};
uint8_t buff[100] = {0};
void setup()
Serial.begin(9600);
Wire.begin();
uint8_t buf[4] = {0};
uint16_t data, data1;
float temp;
float hum;
void loop()
readReg(0x00, buf, 4);
data = buf[0] << 8 | buf[1];
data1 = buf[2] << 8 | buf[3];
temp = ((float)data * 165 / 65535.0) - 40.0;
hum = ((float)data1 / 65535.0) * 100;
Serial.print("temp(C):");
Serial.print(temp);
Serial.print("\t");
Serial.print("hum(%RH):");
Serial.println(hum);
delay(500);
uint8_t readReg(uint8_t reg, const void* pBuf, size_t size)
if (pBuf == NULL) {
Serial.println("pBuf ERROR!! : null pointer");
uint8_t * _pBuf = (uint8_t *)pBuf;
Wire.beginTransmission(address);
Wire.write(®, 1);
if ( Wire.endTransmission() != 0) {
return 0;
delay(20);
Wire.requestFrom(address, (uint8_t) size);
for (uint16_t i = 0; i < size; i++) {
_pBuf[i] = Wire.read();
return size;
All our product design team (the ones that would usually consider making a port) are tied up with our PiicoDev and other ranges, but we’re happy to help with any snags you have if you want to give this a crack yourself ![]()
Hi Clint,
ChatGPT is pretty handy for porting small libraries like this (GPT4 ought to work if ChatGPT doesn’t).
Thanks James - I will have a crack.
Thanks Liam - I will try ChatGPT
