Hi.
You guys sent me a JST connector cable set the other day - very impressed with the service! You treated my lousy $20 order as though it was for $20,000! thanks!
Anyhoo, it is the wrong size - my bad, I got exactly what I ordered. This is all new to me!
Hopefully I have attached a photo of my existing plug that I am trying to replace, in the hope that you can identify exactly what I need. Forv the record, I just need one pre-wired female connector. If it didn’t work please give me a ring so that I can try again. Cheers.
Hi Graham,
I am pretty sure you are after a jst ph 1.75 /6. Pitch of 1.75mm and 6 inputs. I am having difficulties finding if we stock anything that will work here. But I am pretty confident that is the connector you are after.
Thanks Jack. If you can find one, I will be your friend for life.
Chers
GeeBee
If you don’t mind cutting off that connector I have a pretty good solution.
These clips bite into the wire to get a connection so there’s no additional soldering needed. Could be a good workaround. We don’t have a 6 pin one though but 2 3s could do that no problem. Otherwise I have found 1 place online with something similar that has been retired.
Let me know what you think.
Hi Jack
This might be worth a try? My measurement of pitch may be off a tad. Happy Tom order this if you think the rest of the housing will fit my socket.
- Breadboard to JST-ZHR Cable - 6-pin x 1.5mm Pitch
Thanks again
GeeBee
Sounds like it would be worth a try! Shall I place an order or can you send me an invoice and send them my way? And thanks again - excellent service!!!
GeeBee
Hi Graham,
Thank you kindly for the praise. Feel free to place an order and we can get that to you swiftly.
As for the Breadboard to JST-ZHR Cable - 6-pin x 1.5mm Pitch. You can get away with a different pitch sometimes but usually for 2 pin connectors
It’s been a pleasure to help.
Me again. Forget the last email. I have ordered a couple to give them a try.
Cheers mate
GeeBee
Great to hear it. I look forward to seeing your completed project
