Core
20 March 2025 01:51
1
This is a placeholder topic for “Jumper Wire - 0.1”, 4-pin, 12"“ comments.
This is a simple four wire cable. Great for jumping from board to board or just about anything else. There is a 4-pin JST RE connector on both ends. These are simple jumper wires used on standard 0.1” breakaway headers.
I am looking for a jumper wire and connector like this one (Jumper Wire - 0.1", 4-pin, 12" | Buy in Australia | PRT-10374 | Sparkfun | Core Electronics ) but about 60 cm long. Yes I could join two together but does anything like that exist as a single product? Or even a 4-way cable with different types of connectors but still 60 cm long.
Dan
20 March 2025 02:22
3
Hi @Steve89086
We stock Ribbon Cable Premium Jumper Wires 10-Color F-F 24" (60 cm) | Buy in Australia | POLOLU-4569 | Core Electronics if you’re specifically wanting a 1x4 connector on the end of it you will be able to gently lift the plastic retaining tab on the black housing that comes with them and pull the wire back out, from there you could look at reinserting them into something like this 0.1" (2.54mm) Crimp Connector Housing: 1x4-Pin 10-Pack | Buy in Australia | POLOLU-1903 | Pololu | Core Electronics
