I would like to build an LP case with detachable/lid 10" Monitor. The default fpc ribbon for https://core-electronics.com.au/10-1-1200-x-1920-ips-display-for-lattepanda.html doesn’t like like it would handle much abuse.
I can’t find any specs for pin and pitch, so does any one know of, or can suggest a more durable ribbon ?
Or specs so I can match up or build my own?
Thanks Axle
Hi Axle,
The OEM Data sheet (including pinout) is available here: https://github.com/LattePandaTeam/LattePanda-3D-Models/raw/master/Accessories/10%20inches%20display/10.1%20inches%20display%20quick%20datesheet.pdf
You’re right, that ribbon cable is really only meant to be reconnected a few times - it’s intended for internal use.rather than external and continual removal.
Looks like Toshiba and TI make some MIPI -> Display Port/HDMI conversion chips, and I’m sure there’d be some cheap chinese clones available, but it seems to be a pretty hard thing to find.
http://www.ti.com/interface/hdmi-displayport-mipi/overview.html
Oliver
Support | Core Electronics
Thank you much, I appreciate the reply. I looked about and nothing generic came up easily. I’ll wait till the display arrives and pursue it then. I’ll post back what I end up with
