This is a placeholder topic for “LED Flexible Strip Light (White)” comments.
This is a flexible LED strip(white) with 160 LEDs per 50cm. It can bring extremely bright and evenly distributed light when powered at 5V DC. There are power soldering … read more
Hi, May I know what would be the best way to drive this LED flexible strip light with an Arduino Due GPIO? (possibly with PWM to control the brightness?) Thanks!
The device you are after is a MOSFET Relay, like this one:
It will switch 5V at high current at up to 1Khz. If you connect it to an Arduino PWm output the PWM rate controls the brightness.
Thanks Jeff for the info. Interesting! I’ll have a look. Cheers!
Good tip Jeff! Always great to see the community helping each other out
