Looking For 12.3" to 14" Screens for Custom 3 screen monitor setup
Hi All,
I am currently working on a project were I am required to produce a triple monitor setup using only 12.3" to 14" monitors, I was looking at laptop screens as a possible solution but this will require driver boards as well to control the display. The minimum resolution needs to be 1920 x 1080 and needs to have displayport or DVI connections on the driver board.
I saw the Qualia Bare Driver Board for LP097QX1 Display but this is for a 9.7" display, would this be able to drive a larger LG based display?
Any help would be greatly appreciated.
Hello Scott,
Unfortunately, we don’t have a 12.3-14" monitor with the resolution that you require. I’ve linked the closest that we’ve got below. That said, you could likely use the laptop displays with an appropriate driver, it will mainly depend on the standards that the displays use and which driver boards will be compatible. What standards do the laptop displays that you want to use have?
Bryce
Core Electronics | Support
Thanks Bryce,
But the customer has thrown me another curve ball, and this will have to be a custom monitor as the aspect Ratio has to be 1024 x 255.
Thank you for all your help.
Kind Regards,
We are now on social media!
Hi Scott,
Yes, that will likely have to be the case, if you need any further assistance please let us know and we’ll do our best to help.
Have a great day!
Bryce
