Hi All,
I was unable to get the Core-Electronics uGateway (CE06076) connected to my WiFi.
I tried the https://core-electronics.com.au/tutorials/ugateway-wifi-setup.html which did not work (I have used this method before for other RPi devices. As a point of note: The above link shows screen images with “boot” as the drive name. My shows “Restore” as the drive name.
In the end, I bought a HDMI cable and a OTG - USB adapter and manually set the SSID and password. It now connects to my network and internet.
Is there a spot I can download a uGateway SD card image from?
I noticed that the Rx LED is constantly lit?? I was expecting a bit of Rx/Tx polling.
I used the update script via the desktop folder but this did not change anything.
How do I know if it is connected to LoRaWAN/TTN?
In https://core-electronics.com.au/tutorials/ugateway-other-tips.html, I found some links to see if the uGateway is connected to the TTN but how do I determine what the EUI is? There is not a region-select.sh script in the folder.
Final question, how do I specify my location ie longitude and latitude?
Thanks,
Neil.
