[quote=“mrblac, post:11, topic:263, full:true”]
It prints with supports because I have that option picked.[/quote]
Nice, I understand and was more-so leaning to how difficult those supports were going to be to remove from areas such as this (which are less than 1mm thick, it’s going to be challenging!)
I’m guessing no supports were built up to the top overhang (the actual antenna on the mast, at the top of the print); that would be due to the awkward placement of the ‘floating’ object below it (which could be moved easily enough in Cura).
Plus I’m printing it solid now too, so there’s no problems on small wall thickness as well.
That’s not entirely true. Towards the top of the print, the hotend will spend a lot of time going around in circles which can/will affect the quality of the following layers as the plastic hasn’t cooled enough.
The show-stopping issue is @17.5 mm height, this object is 3.62 mm wide, at it’s widest point. The remainder of this object is <1.5mm wide. The nozzle size on the Mini is 0.5mm, which leaves you with a max 7 lines of resolution at the widest part of this object (which is fine). Other parts of this print (the mast, etc) will be printed with more limitations, many areas are less than 1 nozzle width. This doesn’t seem like a normal object to 3D print, from my experience, it is going to be arduous and involve lots of tinkering with heat/material limitations which will get it over the line, but it’ll be a slog!
If you feel your printer isn’t working properly, then get the best quality print you can, send us the gcode, along with the details of material you are using. We’ll load up the gcode and same material. This will produce the exact same object, and isolate if it’s hardware or software.
With that said, you don’t have to engage us as the best way is to simply go back and print a known good “printable” object such as the Lulzbot Roktopus.
