Makerverse Motor Driver motor speeds
Hi, I have an issue where I have a makerverse motor driver hooked up to 4 motors on my Rover robot. The front and back motors are wired together so that the left side moves together as does the right. I am using N20 motors. The issue is that I cannot seem to drive the sides at different speeds. Here is some example code that I am using. Both sides run at the same speed. If I drive each side separately I can change their speeds so everything seems hooked up properly. Here is the code:
#define MOTOR_LEFT_PIN 9
#define MOTOR_RIGHT_PIN 3
#define DIR_LEFT_PIN 2
#define DIR_RIGHT_PIN 4
void setup() {
  pinMode(MOTOR_LEFT_PIN, OUTPUT);
  pinMode(MOTOR_RIGHT_PIN, OUTPUT);
  pinMode(DIR_LEFT_PIN, OUTPUT);
  pinMode(DIR_RIGHT_PIN, OUTPUT);
  // Set both motors to forward direction
  digitalWrite(DIR_LEFT_PIN, HIGH);
  digitalWrite(DIR_RIGHT_PIN, HIGH);
void loop() {
  // Set different motor speeds
  analogWrite(MOTOR_LEFT_PIN, 100); // Left motor slower
  analogWrite(MOTOR_RIGHT_PIN, 255); // Right motor faster
  delay(2000); // Let the motors run for 2 seconds
Schematic_Rover-v4.5-carrier-board-1.4_2024-11-29.pdf (116.1 KB)
I have uploaded the schematic of my PCB as well.
Many thanks
Pete…
Your code seems to be driving each motor separately: there should be no connection between the two separate analogWrite commands. Do you mean that you can control the speed when you are driving only one motor at a time? I suspect the important bit might be the connection from the MCU to the motor driver. Which Makerverse motor driver are you using and how is it wired in?
When you run both motors, is it always the same one that controls the speed, and which one is it? Or do both motors run at the higher (or lower) speed setting, regardless of which motor that is?
Hi Jeff,
Many thanks for replying!
A slight update. It seems that they do drive at different speeds (the left and right sides). However, it seems that the faster side forces the wheels on the slower side to speed up until they are both travelling at the same speed. Almost like the motors ‘give in’ to the friction or something.
Here is the code I was just testing with. If you hold the robot in the air, you can see the different speeds on each side. When you put it down, it starts to turn but then quickly straightens out.
#define MOTOR_LEFT_PIN 3
#define MOTOR_RIGHT_PIN 5
void setup() {
  // Set motor pins as output
  // Set both motors to drive forward
  digitalWrite(DIR_LEFT_PIN, HIGH); // Set direction for left motor
  digitalWrite(DIR_RIGHT_PIN, HIGH); // Set direction for right motor
void loop() {
  int speedLeft = 35;  // Speed for left motor (0-255)
  int speedRight = 255; // Speed for right motor (0-255)
  // Set motor speeds
  analogWrite(MOTOR_LEFT_PIN, speedLeft);
  delay(2000);
  analogWrite(MOTOR_RIGHT_PIN, speedRight);
  // Keep running the motors at set speed
  delay(1000); // Adjust delay as needed
Another update. It seems, it does make a difference which motors are running. I tested with 200, 300 and 500rpm. With 200 it seems like I can get it to work after a fashion. I changed the code to do this (using my library which amounts to the same thing as before):
    rover.forward(100, 100, 0.5);
    rover.forward(0, 100, 0.5);
    rover.backward(100, 100, 0.5);
If I set one side to 0, it is turning. The forward method parameter 1 and 2 set the speed on left and right sides as a percentage. The 3rd parameter sets the duration of the forward movement.
I think I’ll close this one now.
Hi Pete,
Glad to see that you’ve gotten this working. I’d love to see some images of your rover as it comes together!
Hi Jeff,
I’ll send some over to the forum
The left and right motors might be electrically shorted together somewhere in the wiring or within the motor driver. This would allow them to share the same voltage regardless of separate PWM inputs.
Each motor pair (left and right) should be connected to distinct outputs of the motor driver and not to a shared connection point.
