This is a placeholder topic for “Makerverse PAM8302 2.5W Mono Amplifier” comments.
A tiny, low-noise amplifier to bring sound to your project.
Read moreThis is a placeholder topic for “Makerverse PAM8302 2.5W Mono Amplifier” comments.
Read moreHi.
I’m wanting to use a 5v Trinket to send audio to this speaker. Is this the right amplifier for the job? Is there anything else I need?
That is the speaker they provided in the Makerverse Audio Kit I bought along with the amplifier.
Yet to use the kit, it is for the grandkids to learn on.
So I would say YES it is the right amplifier.
Thanks @James46717
Are there Arduino compatible libraries for makerverse line products or is the focus on python? ![]()
Hi PIx,
Jim is on the money, and keen to see what you make!
PS: If you havent found a driver already there are some good audio-PWM libraries around that get the job done.
Thanks Liam.
Just to clarify, does this amplifier accept PWM or AC?
Hi Pic,
This amp is AC. PWM is a roundabout way of varying a voltage without a DAC. Before grabbing a trinket I’d check that there are libraries of the sort that can output audio. It’s not quite as easy as you would think!
Hmmm. With the synth I want to make I think I want something more robust.
This seems like the right thing.
Looks like that’s designed to work with a Pico. They cost like 10 bucks. Maybe I should rip the bandage off and learn micro-python
I guess I could join the cult, find a HAL, and figure out Rust on embedded systems ![]()
Or I could make it roll with a trinket if I use a few 74HC959s. I might be digging my own grave there ![]()
I’ll leave this blank emoji here which I will later modify to a happy or sad face depending on whether I made the right choice. ![]()
Hi Pix,
Were you looking to play set audio files?
I’d check out the DFplayer if you havent seen it already: DFPlayer - A Mini MP3 Player | DFRobot DFR0299 | Core Electronics Australia
Hi @Liam120347
No I was thinking synthesis. Probably something simple like a cute FM synth. Something to play around with over Christmas holidays.
Do we need the R2R DAC for this amplifier to work with Raspberry Pi Pico? Makerverse 10-bit R2R DAC | Core Electronics Australia
Good news ![]()
This will work with any audio signal.
You could an alternative DAC, Analogue GPIO, or even fake an audio signal with the Pico’s PWM.
I think you will get best results with a DAC of some kind, but it doesn’t have to be the Makerverse 10bit.
With that having been said I’ve recently had a lot of fun faking the signals with some 500uf capacitors and a digital GPIO pin on a raspberry pi zero (which is similar to the pico). The results are mixed; little bit of that 1990s punk rock distortion. The maker-verse amplifier handled all of my shenanigans like a champ ![]()
Does that answer your question? ![]()
Pix ![]()
