Metal DC Geared Motor - 12V 100RPM 42kg.cm (FIT0492-B)
This is a placeholder topic for “Metal DC Geared Motor - 12V 100RPM 42kg.cm” comments.
This is a metal DC geared motor, 100% pure copper coils, high-density molecular layer, 50:1 metal reducer, small size, large torque. The maximum torque could arrive 42 kg.cm, stable and durable!
Hi I have ordered this motor. Metal DC Geared Motor - 12V 100RPM 42kg.cm I forgot to order mountings for it. Can you advise the mounts needed and if it can be added to my order before it ships to save me more shipping costs?
Hey @Kristine303831,
Welcome to the forum!
The motor has a 37 mm outer casing, so any bracket designed for that size should work. A good option is something like this clamping mount: 1400 Series 1-Side 2-Post Clamping Mount – 37 mm Bore
Other brackets may work too, but be mindful of the mounting hole patterns as they can differ between gearmotor models. If you’d like to use a different type of bracket, look for ones made specifically for 37 mm motors with a compatible hole layout, rather than the stamped Pololu version (as its mounting holes don’t align very well with this motor).
