Hi all,
I’m looking for a replacement for this motor (brushes are worn out).
The dimensions are approx. 18.5 (flat-flat) x 24 (dia.) x 30.5 (long) mm.
It’s not 130-size!
It’s for a (12V DC) car tailgate lock, but I can replace just the brushes.
The system provides voltage for a brief moment, so one-to-one gearing is required.
Any help would be appreciated
Hi Peter,
No worries, what’re the dimensions?
Bryce
Core Electronics | Support
Hi Bryce,
The dimensions are in my post
Ah, thanks for the edit Peter,
This one appears to be a little smaller, however, you should be able to use this, or a similar motor to be able to get the sufficient torque when provided 12V to perform the same function assuming it fits correctly. If there’s anything else that we can help you with please let me know.
Bryce
Thanks Bryce!
So, no direct replacement?
Hey Peter,
Sadly not that we supply. However, if you check in with the manufacturer of the car they may be able to get the exact part for you. All the best Peter! Make sure to let us know if there’s anything else that we can help you with.
Bryce
Try these. They are the motors used by Toyota for Windows etc.
Mat
Good find Mat
Regards,
Oliver
Support | Core Electronics
Thanks Matt!
You found a replacement even though I mistyped the dimensions (24.2mm dia., not 19).
