Can anyone suggest an infrared sensor to use with a Micro:bit as I’d like to build a thermometer in a STEM group situation at school. Also can anyone help with the block code to run, I can’t find anything to support this type of work.
not shore if this is the kind you need but look at this
http://www.microbitlearning.com/code/arduino/mlx90615-infrared-thermometer-and-microbit-example.php
