Stephen just shared a new tutorial: "Micro:bit Soil Moisture Sensor"
The Micro:bit is great for small portable projects like a soil moisture sensor. In this tutorial, we will walk through how to program a Micro:bit to make a reliable and consistent soil moisture sensor that will give consistent readings. The goal of t…
I did this project using components al available through Core Electronics.
I created a 5minute video that shows the setup and hopefully helps to explain a similar code!
Awesome work @Andrew93113 ! Really clear tutorial, it’s well put together
