This is a placeholder topic for “Micro-HDMI to Standard HDMI 1M Cable” comments.
Used for the Raspberry Pi 4 Model B and other devices that have a micro-HDMI output on them, for connection to full HDMI displays.
Hi, does this Micro HDMI cable support Audio?
I’ve had no success with Audio since I purchased it, and I want to make sure I’m not doing anytging wrong.
Hey Hilton,
It should provide audio.
Follow this tutorial through to make sure everything’s working as expected on the Pi.
Does this cable support CEC for HDMI control of KODI?
Hey @Richard296399 , Welcome to the forums!
This cable will support CEC. All modern HDMI cables are capable of allowing CEC communication; it will likely be the devices on either end of your system that prevent you from using CEC. As long as your output device supports CEC, you should be good to go with this, or any HDMI cable!
