microSD Adapter (CE09444)
This is a placeholder topic for “microSD Adapter” comments.
If you need to load or store large amounts of data, look no further than this 3.3V SPI microSD card module.
Just like to make a note that the pinouts listed in the description are not correct for this module. I have ordered a few of these and verified they work with the below pinouts. I tested from 4Gb to 32Gb uSD’s.
If you have the pins up facing you on the left, with the SD card to the right, showing the SD text upside down (generally), That is with the little arrow pointing up, the pins are as below from top to bottom,
  1. VCC, 3v3
  2. CS
  3. MOSI
  4. CLK
  5. MISO
  6. GND
Hi Max,
Welcome to the forum, I had seen a note made about this one in the past we just hadn’t confirmed the pinout. I’ve just tested one myself and have updated the page.
Thanks for the assist.
Yeah, no probs. Thanks for the quick reply too,
It’s a top little module for the price. I tested it on an Arduino Nano and currently running on a RPi Pico. Hoping with a smaller RTC I can squeez my project into a small tin, about half the size of the Altoid tins.
Maxx.
Good luck! That’s one small container to squeeze that all that in.
New Topic/ Question
  1. is there a datasheet ?
  2. Tech Drawing ?
  3. CAD Model ?
  4. Outside dimensions ?
Hi, @Katherine306977, and welcome to the forum. Glad to have you here.
The exact design of the SD Card Reader has changed over time which is probably why the exact dimensions are not listed on the page.
However, with some calipers, I can give the exact dimensions of the PCB as:
  • 18mm (W) v 18mm (L) v 2mm (H)
With the SD components attached, however, maximum dimensions do change due to the pins and SD Card slot hanging over the board giving the below maximum dimensions:
  • 18m (W) v 21mm (L) v 11mm (H)
Images for clarity:
Just to add for anyone else - if you’re using this with an Arduino, remember it’s a 3.3V logic module! I’ve seen a few people try to plug it directly into 5V pins and run into issues. Definitely keep it to the 3.3V rail for safety.
Good point, Brittany.
You definitely don’t want to use the wrong overvolt an SD Card Adapter!
