This is a placeholder topic for “Mini 8-Way Rotary Selector Switch - SP8T” comments.
When you need a lot of options, you need a Mini 8-Way Rotary Selector Switch. This is basically a single-pole to 8-throw switch. As you rotate the knob around, the … read more
re Mini 8-Way Rotary Selector Switch - SP8T
What diameter is the threaded shaft? And also the shaft which holds the knob?
Bob.
Hi Bob
If you click on the link to Core web page there is a drawing. The threaded bush is 9.3mm and the splined shaft is described as T18 size. Now I have no idea what that means. Maybe Adafruit’s sizing system but the only place I have heard of that terminology is Torx driver sizing. It may have 18 teeth, I haven’t counted them. The drawing shows this shaft as 4.5mm which I think is a pretty odd size and I would question that. I have quite a few pots etc with splined shafts and they are all 6mm (5.96). I have only heard of this type described as “Metric splined” implying 6mm as against 1/4 inch for round or “D” shafts.
I could be wrong here and this T18 is a size which has sneaked in under my radar and if the drawing is true you might find yourself having to purchase knobs to fit from Adafruit or Core. I might check Element 14 later and see if this size exists in the commercial world.
EDIT: Just had a look at Element 14 for that shaft diameter.
8 pos switch only 1 listed. seems to be an odd size.
Plenty of different shaft sizes, too many to go through but of the ones I did look at 4.5mm was not listed.
I did look at pots. There was a filter for shaft diameters and I found the following.
4.5mm Qty listed 1 “D” shaft
6.35mm Qty listed 342 mostly D shaft
6mm Qty listed 389 spline and D
I think it would be best if Core staff were able to measure this for you.
Hi Bob,
Unfortunately, the only info we have from our supplier is this fuzzy image:
However, it does reveal that the threaded section is M9x0.75, and that the splined section is 6mm with T18 splines.
Mouser have a category for these knobs, so they do exist elsewhere, and from the look of things, it just refers to the tooth count: Knobs T18 Knobs & Dials – Mouser Australia
We’ve also got a range of knobs available if you’re looking to get one from us:
All the best with your projects!
Thank you. I think the threaded bit is too short to go through a guitar body.
Appreciate your reply!
Bob.
Tuesday, September 14, 2021, 1:47:06 PM, you wrote:
Hi James
Pretty disgusting actually.
So disgusting I missed the splined shaft dimension in the top left image. It does say 6mm.
BUT. The dimension I did see is on the centre image plainly says 4.5mm.
So for the sake of compatibility if we assume 6mm it is possible any “standard” “metric” knob would fit.
Not difficult for Core to measure though surely.
Hi Bob,
Looking over that diagram it looks like the switch is drawn with a D-shaft instead of a T18 splined shaft. I’ve made a note to have that product page reviewed and updated to see if we can get a more accurate drawing from the manufacturer. Failing that we may need to remove the diagram and just list our own measurements and descriptions from the warehouse stock.
Hi Trent.
You are right. I missed that. Must be getting sloppy in my old age, more likely a bit slow. That’s my excuse anyway. I think we might blame whoever produced that drawing and more to the point who checked it. Sloppy QA, but that sometimes seems to be the norm these days. Not always thank goodness.
Hi Robert,
Thankfully, I’ve been able to measure a unit from stock, and confirmed the dimensions. The discrepancy between the shaft measurements is likely due to the D-shaft seeming smaller from the side, and the correct measurements are at the bottom now.
We’ll see if we can find a better diagram, but that should tide you over until then!
frustrating switch. ADA doesn’t list the rating of this switch. No voltage or amps mentioned. Does anyone know how many amps this switch will sustain at 12v DC?
TIA
Hi Paul,
Welcome to the forum!
I understand your frustrations but thats sometimes the case with hobby parts. If I were you I would compare it to another switch that handles logic level signals from a microcontroller (3-5v at around 20mA). If you need to pass higher currents from one of the outputs you could use a MOSFET switching circuit. Here’s an excellent one: https://core-electronics.com.au/freetronics-n-mosfet-driver-output-module.html (Bobs favourite
Another way to figure out the max ratings would be to do some destructive testing, you have 8 samples from the one switch! Just make sure you wear some PPE
do you have the ratings for this switch? I need to check the amperage it can sustain at 12v DC.
Cheers Paul
most rotary switches like this one are 0.3 amps or less. So I have been looking further. The mosfet option is valid except the switch can drive 8 of them starting to make it messy and expensive. I could do an array of four toggle switches sp3t on-on-on except these are hard to find cheaply. The reason for an eight way switch is to make it simple.
Probably the easiest - really old school - would be to replace the switch with a plug board ie 1900s to 1940s technology used by phone operators and evil nazi coders,
Hi Paul
See if you can find one similar on Element 14. They publish data sheets for almost everything they stock and I feel sure you will get your info here. There is a little Adobe icon in the listing and one click and you are go.
Hi Paul
Just how many amps do you need to switch. There are 2 values here. Contact current handling capability and contact switching current capability. The contacts will carry more than they can switch, if you switch at zero current it is better.
Also old multimeters and other test gear. More reliable than switches in those days.
