This is a placeholder topic for “Panel Mount 10K Log Potentiometer w/ On-Off Switch - 10K Log w/ Switch” comments.
This potentiometer is a two-in-one: it’s a log taper 10K ohm potentiometer, with a grippy shaft and it comes with an on-off switch. It’s smooth and easy to turn, … read more
10k log potentiometer with switch - What is the length of the shaft in mm?
Hi Sergio,
The shaft is 15mm long total, with twisting part of the shaft being about 9mm.
Hope this sorts you out!
