I’ve got a project that I’m doing that requires RFID readers embedded in scrabble tiles to read NTAG213 tags stuck on the back of the scrabble tiles. The tiles are 18mm x 20mm.
I initially bought some PN532 readers; but they turned out to be 54mm x 48mm - way too big to put into a scrabble tile.
Are there any other options to get smaller compact readers. I had a look at the PN5321 with antenna; but that becomes very expensive when I need 30 readers. AI suggested using external antennas with the PN532; but I’m not so sure that would work.
Vivek
Im trying to picture what you are wanting to do.
RFID NTAG213 is passive 14a, so the reader needs to send power to the tag, so the tag can power up and talk.
When you say tile, do you mean a portable tile that you place on the board, or are you talking about a single place on the board where someone can place the ntag and then have the reader read it?
Since RFID is a near field thing, you would need to make sure you can read the actual tag and know you got the correct on.
if more then one tag is in the field then you would use an anti collision to get the IDs of each tag; If you keep track of the existing tags then the new one should be the one not in your list, but if you have more then one then do you know where it is, i.e. directly on the reader or to the side of it.
If you could track the X,Y and just need the ID of a tag… 15a is much better at “longer” distances and multi tags in the field…
But, Im kinda guessing what you are trying to do…
I’m sticking NTAG213 tags on the back of scrabble tiles.
What I want to do is embed the readers into a scrabble tile rack so that when the tiles are placed on the rack; the readers can read what tiles have been placed where. I’ll connect the readers to an ESP32 device that can do the mapping from the tag id to the letters and then transmit the letters to another device.
So, I need something that I can embed into a hollowed out tile rack. My initial idea was to use readers placed next to each other directly under where the tiles would be placed and hope that there would be enough distance to prevent interference or detection of multiple tags. But, I need a reader small enough to match the tile size to be able to do that.
Cheers, Vivek
