This is a placeholder topic for “PiJuice 2300 mAh Battery - Compatible with PiJuice” comments.
2300 mAh Lithium Ion battery that can be used with the PiJuice HATmodule. The PiJuice HAT comes with a 1820mAh as standard, so this 2300mAh will give you a little extra boost!
You have PiJuice solar with 2300mah battery ?
Hi James,
Welcome to the forum!!
We dont have a kit ready to go but you can certainly make your own up, check out this range of parts: Pijuice Australia
You can change out the battery and add a solar panel as required ![]()
