Hi Mark.
It doesn’t look like we have one that matches exactly this exact pinout.
This one from Pololu look the closest with this one from sparkfun also has all those pins.
Hi @Mark141278 - i’m not sure what you mean by your question.
All SD card breakouts will break out these pins, it’s up to you to make the correct connections ie.
Connect the SCK pin to the Dev-Board’s IO36 pin.
