Raspberry Pi Zero W V1.1 and the latest version of Raspbian
root@raspberrypi:~# uname -a
Linux raspberrypi 4.9.45-v7+ #1031 SMP Fri Aug 25 19:02:16 BST 2017 armv7l GNU/Linux
with I2C and SPI enabled, UART not enabled
Based off that, it sounds like you’ve done everything right with that install. If you’ve already ordered a second board, then it might be best to wait until you’ve got that, and see if that works, in which case we can sort out the faulty hardware, and if not, we know it’s not a hardware issue.
It is resolved, actually the problem was with me connecting display the other way around. Thanks to everyone, special thanks to Francesco from Pi Supply
