Hey Guys,
So i’ve been busy adding some sensor’s (BME280, ENS160, VEML6030), which i think i’ve managed to get working fine…whilst connected to USB. When i ran the setup on battery i noticed that all the Air Quality Sensor Data were: “eCO2(value=0, rating=‘invalid’),operating ok,0,AQI(value=0, rating=‘invalid’)”. Basically, i’m just wondering if there needs to be a little more of a delay when grabbing the eCO2 Data because it seems like the sensors didn’t have enough time to initialise. Or i’m doing something wrong.
This project requires the Plant_io module which handles
- Interfacing with electronics (pump, moisture sensor, PiicoDev modules)
- Datalogging to a file
Plant_io removes a lot of setup complexity from PiicoDev but is only compatible with select modules.
from time import sleep_ms
from Plant_io import Plant_io, DataLogger
while True:
### Step 1: Initialise the Plant
plant = Plant_io()
plant.moisture_setpoint = 80 # change this to tune how moist the growing media should be. Use the results from test_moisture_sensor.py
# Attach sensors. Comment-out any sensors you are not using.
print("Initialising PiicoDev modules")
plant.attach('BME280') # Atmospheric Sensor
plant.attach('ENS160') # Air-Quality Sensor
plant.attach(‘VEML6040’) # Colour Sensor
plant.attach('VEML6030') # Ambient Light Sensor
plant.attach(‘VL53L1X’) # Laser Distance Sensor
plant.attach(‘LIS3DH’) # 3-Axis Accelerometer
plant.attach(‘QMC6310’) # 3-Axis Magnetometer
print("")
### Step 2: Collect some data to log
soil_moisture = plant.measure_soil()
voltage = plant.measure_system_voltage()
Ambient Light Sensor VEML6030
lux = plant.VEML6030_light()
Atmospheric Sensor BME280
temperature_C, pressure_Pa, humidity_RH = plant.BME280_weather()
Air-Quality Sensor ENS160
ENS160_status, AQI, TVOC, eCO2 = plant.ENS160_air_quality()
Colour Sensor VEML6040
hsv = plant.VEML6040_HSV()
rgb = plant.VEML6040_RGB()
Laser Distance Sensor VL53L1X
distance_mm = plant.VL53L1X_distance()
3-Axis Accelerometer LIS3DH
acceleration = plant.LIS3DH_acceleration()
Magnetometer QMC6310
plant.QMC6310_calibrate() # should only need to run once. Comment out once calibration is complete.
flux = plant.QMC6310_flux()
polar = plant.QMC6310_polar()
### Step 3: Run the pump if plant requires water. This function uses soil moisture to decide whether to run the pump or not.
pump_running_seconds = plant.run_pump_control()
# Print some debugging information
print(f'Moisture {soil_moisture:5.2f}% Pump Time {pump_running_seconds:5.2f}s')
### Step 4: Log the data to a file
period_minutes = 20 # The chosen interval time on the Makerverse Nano Power Timer
file_name = 'log.txt'
# These are the labels that appear at the top of each data column in the log.txt file
# TODO: Add your heading titles here
heading_time = 'Time [minutes]'
heading_moisture = 'Moisture [%]'
heading_pump = 'Pump Run [seconds]'
heading_voltage = 'Supply Voltage [V]'
heading_lux = 'lux'
heading_temperature = 'Temperature [C]'
heading_pressure = 'Pressure [Pa]'
heading_humidity = 'Humidity [RH%]'
heading_ENS160_status = 'ENS160_status'
heading_eCO2 = 'eCO2 [ppm]'
heading_AQI = 'AQI'
heading_TVOC = 'TVOC [ppb]'
data_heading = [heading_time, heading_moisture, heading_pump, heading_voltage, heading_lux, heading_temperature, heading_pressure, heading_humidity , heading_eCO2 , heading_ENS160_status, heading_TVOC, heading_AQI ,] # The heading that will appear at the top of the log file
logfile = DataLogger(file_name, data_heading, period_minutes) # Open the log file, and write the data_heading if the file was just created.
timestamp = logfile.last_timestamp + period_minutes # get the most recent timestamp
# Construct a data dictionary - dictionary keys match the data headings eg. {heading string : data to log}
# TODO: Add your sampled data here
data = {heading_time : timestamp,
heading_moisture : soil_moisture,
heading_pump : pump_running_seconds,
heading_voltage : voltage,
heading_temperature : temperature_C,
heading_pressure : pressure_Pa,
heading_humidity : humidity_RH,
heading_lux : lux,
heading_eCO2 : eCO2,
heading_ENS160_status: ENS160_status,
heading_TVOC : TVOC,
heading_AQI : AQI,
logfile.log_data(data)
### Step 5: Signal to the Makerverse Nano Power Timer that we are DONE!
# This removes power from the project until the next timer interval
plant.sleep()
### Step 6: If we are running from USB power then power will never be removed by the Nano Power Timer.
# Instead we can just insert a delay. When powered only by batteries, this code will never run.
sleep_ms(round(1000*60*period_minutes))
