This is a placeholder topic for “Pogo Pin Probe Clip - 2x5 1.27mm Pitch SWD” comments.
The Pogo Pin Probe Clip with 2x5 0.05" pitch SWD spacing is a great way to test and connect with pin-point accuracy without soldering! It's sort…
Read moreThis is a placeholder topic for “Pogo Pin Probe Clip - 2x5 1.27mm Pitch SWD” comments.
Read moreHi,
With the Pogo Pin Probe Clip - 2x5 1.27mm Pitch SWD is it possible to connect with jumper wires on all 5 pins from this direct to a stlink v2 clone (preferred) or a raspberry PI or do you need another adapter in between?
Hi Sean,
Since STLinks generally use male header pins, just some F-F jumpers would be what I’d suggest, that would allow you to use the clip for other programming setups down the line, or make adjustments based on a board manufacturer’s particular preferences for SWD.
