Polymer Lithium Ion Battery - 3.7V 1000mAh (CE04377)
Hi, I’m curious if you have details of the PCM on these batteries. I’m interested in what the cut off values are for the over voltage, under voltage, and over current are? Is there built in over temperature protection or is that more done on the charger side? Do you know what the IC that is used for the PCM is?
Hey Angus, welcome to the forums!
I found the datasheet for these batteries and it seems to have answers for most of these questions.
Anything further may require some hands on testing so hopefully it has enough for you.
Hope this helps!
Sam
