Welcome to the awesomeness that is LiPo batteries. Polymer Lithium Ion batteries offer superior energy density with this 1000mAh battery being only 6mm in height!
You can go off the image and see the polarity of the connectors with regards to the JST connector (the little grove on the top gives it away), however, to ensure the design is right the first time, perhaps just wait for the battery to be 100% sure.
Hi - Is it possible to series up a number of your LiPo cells (1100mAh) to achieve a higher voltage battery? Is the regulation electronics OK with this?
While it is possible to connect LiPo pouch batteries in series to get higher voltages (this is what manufacturers do) it becomes difficult to charge them safely as multi-cell LiPos need to be balance charged.
I when looking at the consequences of getting it wrong I think you are better of finding a battery manufactured to meet you needs, you may find racing drone batteries suitable.
I’ve linked a battery below as an example, it has an XT30 discharge plug and a JST-XHR balance charge lead (so the charger can ensure all cells are the same voltage during charging)
Thanks for the input Trent – as you guessed, I am seeking a LiPo battery for my Parrot Bebop 2 Power drone. They seem to be incredibly hard to find (I haven’t found one yet) and getting them to Australia seems impossible (nobody will transport them). Your link to Hobbyking gives me some hope, but a quick look suggests I will still struggle to find one that fits the Bebop.
I would have a look at PhaserFPV for some local drone parts, there are certainly some higher cell count’s around but as Trent mentioned there are a lot of safety considerations that come into play when using a LiPo battery!
Then, Yes, the specification sheet says LiPo 3.7V and about 14mA active.
So, 3.7V 1100mAH would do just fine, should run for a couple of days no problem.
What information in particular were you after?
I dont have one of these and I cant garuantee anything but 0.5C seems to be a safe voltage for LiPo’s, even up to 1C (From Core’s guide).
